Musina₼ [(+27633867063*)] ₼ Abortion Pills For Sale In Musina Clinic In Musina,DELAREYVILLE,EAST LONDON,MOSSEL BAY,THOKOZA,DLAMINI,HANKEY,PHUTHADITJHABA ,KEMPTON PARK,QUEENSTOWN - (Obstetrics and Gynecology) Medical abortion is a safe and effective method of terminating a pregnancy up to 16 weeks gestation using medication (abortion pill) rather than surgery. Medical abortion, also known as non-surgical abortion, is now available all over South Africa. Our Pregnancy Termination Pills Are Effective 100% Of The Time After A Pregnancy Termination Procedure You May Experience Slight Nausea, Vomiting & Light Bleeding Which Is Normal During An Abortion Process. Abortion Or Pregnancy Termination Is Legal In South Africa. You Do Not Need The Permission Of A Parent Or Partner To Terminate Your Pregnancy.. How does a Medical Abortion Work? It works by blocking the hormone progesterone, which is necessary to sustain pregnancy. Without this hormone, the lining of the uterus breaks down, the cervix (opening of the uterus or womb) softens, and bleeding begins. Within a few hours days after taking the medication medication it will cause the uterus to contract and empty. This ends the pregnancy. If you are pregnant and cannot afford surgical abortion which is very expensive then consider medical termination with a pill. You will achieve exactly the same results, safely, quickly and cheaply.
