Roster building in Diamond Dynasty often comes down to finding a card that plays above its price tag, and Theo Gillen fits that description nicely. His 99 overall Draft Series item gives players a serious shortstop option without forcing them to drain their supply of MLB 26 stubs. Gillen was the 18th pick in the 2024 MLB Draft, taken by Tampa Bay out of Texas, but his in-game card has flown under the radar. That is a bit surprising. He has the ratings to handle a starting role on plenty of strong squads, especially for players who need more speed and range in the middle infield.
More Than a Cheap Fill-In
The big draw is the cost. Cards with this kind of all-around profile usually sit far higher on the community market, yet Gillen can often be found near 25,000 stubs. For a player putting together a competitive team on a tighter budget, that changes the equation. You are not buying a temporary bench piece. You are getting a shortstop who can stay in the lineup while other upgrades take priority.
Strong contact and power potential from either spot in the order.
Quick enough to pressure catchers and take an extra base.
Reliable fielding for routine plays and tougher balls up the middle.
A throwing arm that holds up on long plays from deep short.
How Gillen Plays on the Field
Ratings matter, but feel matters too. Gillen's swing is the reason many players warm up to him after only a few games. It is compact, easy to read, and does not feel rushed. You can sit on a pitch and still react when something else shows up. He is useful against lefties and righties, which is handy when you do not want to keep shuffling platoon options. At short, his speed shows up quickly. A ball that looks like it is headed through the hole can still turn into an out.
Area What It Adds
Offense Gap power, solid contact, and a comfortable swing.
Defense Range for grounders, clean turns, and dependable throws.
Speed More pressure on the bases and better recovery in the field.
Price High-end production at a much lower entry point.
A Smart Infield Pickup
Gillen makes the most sense for anyone who wants a complete shortstop rather than a one-dimensional hitter. He can lead off, hit lower in the order, swipe a bag, and make the play that saves an inning. There are flashier names on the market, sure, but few offer this much for such a modest cost. If you spot MLB 26 stubs for sale while planning upgrades, Gillen is a sensible place to start, then you can use the remaining budget to strengthen other spots.
Need a reliable shortstop without draining your stubs? Theo Gillen's 99 OVR card brings a smooth swing, sharp defence and the speed to change games. U4GM has useful MLB The Show 26 tips and options at
https://www.u4gm.com/mlb-the-show-26/stubs , so you can upgrade smartly, keep your budget intact and enjoy building a stronger Diamond Dynasty squad.
